2 members (Jeff Ogden, klhansen), 73 guests, and 2 robots.
Topics128,130
Posts1,056,712
Members48,454
#1344548 02/01/2020 12:36 PM
Does anyone have a part number or vendor for the metal gasket on a 46 1.5T rear axle hub? Both sides are leaking.
7
7 Offline
I think you are talking about the gasket between the hub and axle shaft, if the metal is in good shape I would clean all mating surfaces with brake cleaner and use some non-hardening gasket sealer with the original gaskets. Mine were not metal, I made new ones with a medium weight gasket material.
Thank you, I've considered that as well. I have the gasket material to make them, however was curious if new were available.
The best axle "gaskets" are soft metal, either copper or aluminum, and need to be coated with a non-hardening gasket sealer. If there is any movement at all between the axle and the hub, even a few thousandths, a paper gasket will be damaged and start leaking. Bigger full-floater rear hubs have tapered metal cones that grip the bolts tightly and fit into corresponding tapered holes in the axle flange to prevent any movement. 3/4 and 1 ton rear axles usually don't have them, but the OEM bolts have an unthreaded shank under the head that's a very close fit to the holes in the flange.
The original "gasket" on comparable generation 1940-45 military trucks was a malleable lead and tin terne-plate material. If assembled with a non-hardening cement, they seal pretty well. I have sources for the military style axle gasket. Do you have measurements from your gasket...maybe they are the same?
Lots more pictures
