0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1344327 01/30/2020 8:05 PM
Hello everyone, I have the tie rod ends that look like they’re either pressed or welded into place, can someone tell me if I can replace them with the ball tie rod ends that bolt into place or do I have to weld new ones in place, and how do I get the old ones out without tearing the spindles apart.
I have a 54 half ton Chevy pick up.
Thanks for the help
The ball ends are pressed into place and riveted. There is a chamfer in the steering arm on the side opposite the ball. Drill a hole partway through the ball stud and use a large drill bit to cut away the metal that's peened over the chamfer. The ball stud will drive or press out with a lot less effort once that's done, with no damage to the steering arm.
Thanks, so what do I use as a replacement, the type with a castle nut on the end?
You can still get the original type non-threaded ball studs...
https://www.americanclassic.com/193...usfKpyM5Y2oi-T0X2bE3Qp_sJOkaAu5yEALw_wcB
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I'd choose the straight shank balls sized to about a .001" press fit and peen the ends over thoroughly after they're pressed in. If the old ones held for 70-something years, that system seems to work OK. Don't mess with success!
On the other hand, could I use the bolt in ball with the castle nut if I wanted to? Is it the same size?
Can’t say I’m going to use it, just wanted to know if I could and the fit would work.
I used the the ball with the castle nut for my steering arm. They have worked out perfectly.
1951 1 Ton Completed
Thanks for the input, Todd
Brothers Truck supply has a video on you tube on how to replace the ball type tie rod end with the new current style tie rod ends that are available. He puts the steering arm in a vise and grinds off the ball and then grinds the stub down to the arm. Then they are pressed out from that side using a shop press. I plan on doing mine this way.
