7 members (JW51, J Lucas, papas52, Hotrod Lincoln, Gdads51, DadsFirstPickup, 1 invisible), 104 guests, and 2 robots.
Topics128,162
Posts1,056,953
Members48,458
I picked up a rear end for my '51 from what I thought was a 67 Chevy half ton. Well, it's one of the rare rear ends that is a Dana 44 with 3.54 gears and is a posi-trac. That all works out great, but the drums are shot and they don't make them anymore. So I figured why not, we'll just swap it over to disc. But I cant use the kits for the trucks since it has a Ford 9" Big Axle flange pattern. And on top of that I want to keep the 6x5'5" bolt pattern since I've already converted the front to 6 Lug Disc. I found a forum thread where someone machined down a Wagoneer Drum to make it work, but I don't like the idea of having to get custom drums if I ever need them. Has anybody ran into this or have any suggestions? I'd prefer to have bolt on since I don't have access to a welder and can't weld myself. Thanks for any help on advance
1951 Chevy 292 Project
There is an old post on using Jeep drums & drilling out the lug bolt holes, will try to find it.
BC
1960 C60 pasture art
Found the thread, looks like he used a Raybestos 2067 and had to drill out the lug bolt holes. Somehow I missed that thread, I'm going to get one of those ordered in, thank you!
Crusty Old Sarge
Crusty Old Sarge
I have my daughters 03 Chevy Trailblazer that I'm doing some engine work. It has rear disc and 6 lug bolt pattern, has anyone looked at using this axle or the brake set up?
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
We have used the Trailblazer which has a 62.1" track width which is spot on for an AD. Have also used the Colorado/Canyon which also fits well. On some late model six lug patterns the pattern is metric and almost works but not quite.
Evan
Could you post a link to that thread? Been looking for it but I don't seem to have much luck with search function.
BC
Here's the link to the thread about Jeep Drums
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/464898/Re:_66_GMC_rear_brake_problems.html
Thanks Gearhead! I printed it & stuck it in my a folder.
BC
Sir Searchalot
Sir Searchalot
Not sure why you say rare or can't find? PM me if you need help finding.
