2 members (dt235sd, Bucker), 146 guests, and 0 robots.
Topics128,196
Posts1,057,390
Members48,471
#1343515 01/25/2020 1:25 AM
I just scanned a list of 844 posts from a search for “right hand steering”. I didn’t see one helpful post, though I do recall some discussions from the past. A few questions if anyone has some useful info. Thanks.
Particularly I am thinking about A-D and/or N-D trucks (47-55).
Were any right hand steer trucks made in the USA? I guess for export, but maybe for special applications here also? Rural mail carrier, etc?
Were right hand steer trucks made in Canada?
What’s the chance of finding one in the USA?
I remember seeing the John Wayne movie Hatari when I was a kid. Red Buttons drove a right hand steer A-D Chevy truck. It had a non-USA style bed, so I guessed it was made overseas.
Professional Novice
Moderator
Moderator
2 Offline
I don't know anything about them Frank.
I do know Tim's (TPR57C) is a left hand drive and he is in Australia.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
My truck came from Monterey California there were trucks made in Canada that went toSouth Africa and Australia that were rhd I didn’t haves to change mine to rhd
i know you are asking about the earlier generation, but my Task Force factory assembly manual has many references to, and illustrations of right-hand-drive, models..
Do a search on Jim Carter RHD from 1936 on for GM. Seems all for the world were built at the Oshawa, Ontario plant except for New Zealand. They demanded the assembly so parts were shipped to the Petone assembly plant. I have driven several through the years and two things have stuck with me; you do with your left hand what is normally done with the right and you must have GOOD mirrors for US driving. The rides were a Rolls, a Rover, and the little diesel taxi with an open shelf for luggage where a left door would be. Heidt's offers a RHD IFS for AD trucks, probably for the down under guys.
Evan
I am curious as to how many parts needed to be made specifically for the RHD trucks.
How were the pedals arranged left to right?
Thanks for all responses.
Professional Novice
All the R.H. cars I've see had pedals same as ours, throttle on Right, brake in center & left foot clutch. Driving with my left hand on the shifter helps with not grabbing the window crank when trying to downshift!
BC
1960 C60 pasture art
That would make for some interesting challenges to connect the pedals to master cylinder, clutch assembly, and carburetor.
I believe the right side frame rail on my Oakland CA built '46 is stamped and drilled for a right hand drive set up.
1946 1/2-Ton Chevy
