3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#1341471 01/10/2020 11:45 PM
I'm looking for the spare tire mounting bracket for a 49 GMC 1/2 ton. The one that holds the tire on the side of the truck on the running board. I put an under bed fuel tank in and had to cut the under bed tire mount bracket out. Does anyone make an aftermarket bracket. Looked at Brothers and Classic and could not find one.
Tom
You will also need a notched fender on that half ton.
tswillow
Short bed or long bed GMC 1/2 ton?
Carl's good advice pertains to short beds (I think)?
It is the short bed and after I posted the question I realized I needed the knotched fender. I finished painting a few months ago and will not be changing the fender so my plan now it to carry a spare in the bed, up against the front right behind the cab. I will only carry it on trips, like the Hot Rod Power Tour in June. I did mount a jack and tire wrench under the seat.
If you ever want to set-up a side-mount tire-carrier, there are few articles in the Tech Tips (to give you an idea on how you might do it in your year).
My good friend with a ‘50 chevy ratrod keeps a spare tire upside down in the bed with one of those land speed looking aluminum hubcaps with a little finger hole in it to pop it off. He uses the rim like a tool box. Keeps a fuel pump, spare wires, starter, coil, and a bunch of tools and zipties. I always thought that was a great little trick. His bed floor is a screen type thing from a old rock crusher plant so i think he has the tire bolted through it with a wingnut so it stays in place.
