| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13430 08/06/2003 1:21 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I just started having problems with the timming on my car. It has a stumble that feels like a electrical miss at highway speed. I have gone through the electrical system and its still there. The only thing I see wrong is that the vacuum advance moves the points alot ( 15 - 20 deg.)with just a small amount of throttle. Is it possible that the return spring in the vacuum advance is dead? Any thoughts would be appreciated. OH its a 66 mustang 289 v8.
if it dosen't need fixed, break it
#13431 08/06/2003 3:59 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Kedso, does it hitch when backing off the gas or cruising? Also, I'd confirm that there's no vac leak.
35 + years of rollin' steel!
