4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
I want to lower the front of my panel some, and will probably use lowering blocks. I have read to use steel ones as aluminum ones can crack. If anyone is using blocks already, I'd like to hear how it worked out.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Always include year/make/size panel in each post.
Sorry, 1957 panel.
hey pan, i have 3" aluminum in the rear and although i've only done about 600 miles i haven't had any issues. i used mono leaf leaf springs in the front and again, no problems. hope that helps.
Can you post a pic of yours?
Lowering blocks in the rear is easy and preferred.
Front lowering 2.5” lowering spring kit or drop axle is better choice.
Why are blocks bad to put on the front?
I used 4" blocks in the rear, and 4" drop axle on mine.
No probs.
The springs are on top of the front axles. There is therefore nowhere to put blocks to lower the front axle.
Thank you for clarifying that for me. This is, by far, the oldest car I have worked on yet, and I'm still learning my way around it..
