5 members (Brian Moore, texas46, dt235sd, TexasA&M48Truck, Steelonsteel), 59 guests, and 1 robot.
Topics128,022
Posts1,055,381
Members48,422
#1341767 01/12/2020 8:50 PM
Hi Group. I’m embarrassed to say that I did not mark where these brackets are from and I cannot remember. Can someone please help me identify what they are from and where they go?
Thank you,
lytlekj #1341776 01/12/2020 9:14 PM
Is it from 60 to 66,?if so looks like back of hood stop, missing rubber,very important,if right what did I win?
lytlekj #1341796 01/12/2020 10:31 PM
Pat you win. Hood bumper brackets. Look for matching holes up on the bend on the cab edge of hood.
~ HB
1962 Chevrolet C10
1962 Suburban
lytlekj #1341856 01/13/2020 3:58 AM
Thanks a million guys! Appreciate the info!
lytlekj #1342260 01/15/2020 3:52 AM
One more part I need help identifying please! Off of 66 C10. Thanks in advance!
lytlekj #1342273 01/15/2020 8:42 AM
Dont have a good sense of size, but I have known this door bracket to rust like you have shown. Maybe?
~ HB
1962 Chevrolet C10
1962 Suburban
lytlekj #1342282 01/15/2020 12:08 PM
Hambone, just a note on aftermarket door checks, should verify that they actually stop door before hitting cowl extension, upon final assembly of my 66 realized aftermarket stop didn't limit door before paint was damaged on door,replaced with original and problem solved, except for knick in paint, Pat66
lytlekj #1342299 01/15/2020 2:28 PM
I checked mine carefully for that reason. My 62 was the mistake case.
~ HB
1962 Chevrolet C10
1962 Suburban
lytlekj #1342553 01/17/2020 12:09 PM
Thank you, I will check that out!!
lytlekj #1343133 01/21/2020 6:34 PM
Hi,
Your second part is a busted door check retainer. Keep it until you get the new one to make sure the new one lines up with your current configuration. There should be a small bar with a roundish hole on one end and a roll pin, and 2 screws/bolts as well.
The picture above is correct, the piece you have that's busted is the part that isn't painted body color.
Good luck.
lytlekj #1343170 01/22/2020 1:22 AM
Since we are talking about door checks for a 60-66 truck, here is a DIY I made. A Jeep Cherokee door check is a popular upgrade because it has two detents. It’s just another option to consider.
JEEP CHEROKEE DOOR CHECK LINK
lytlekj #1343177 01/22/2020 1:53 AM
Great info as always 👍 Lugnutz, do I need a right and left or are both sides the same? I will be keeping this idea in my toolbox for next project. Pat66
Pat66 #1343180 01/22/2020 2:08 AM
Pat66,
Get 2 passenger side front door checks because the PS usually gets less use. The DS and PS door checks are identical. Rear door checks only open to the full stop position. Front door checks have that middle detent.
