7 members (Gdads51, dt235sd, moparguy, Otto Skorzeny, tclederman, Jon G, 1 invisible), 86 guests, and 4 robots.
Topics128,094
Posts1,056,056
Members48,433
#1342004 01/14/2020 12:09 AM
Curmudgeon
Curmudgeon
I was looking at this red 54 on ebay and noticed the rear end. At first I thought the rear tires had a severe case of curb rash and were flipped around. Then the axle stops caught my eye. Picture attached. Surely not? I sent a warning message to the seller but never got a response.
Yeah, those are MayPops. Yikes!
7
7 Offline
Hey good lookin',Tires and tubes are doin' fine but the air is showin' through.
Curmudgeon
Curmudgeon
Once I see something wrong I naturally want to see if there is anything else that looks suspicious. I'm more interested in learning from mistakes than pointing fingers. Critiques appreciated:
1.) Looking at the front axle, why so many nuts on the u-bolts? Spacers? Re-using the old u-bolts with the new spring packs and not enough threads remaining on the old bolts?
2.) The front axle stops, hard to see in the picture, is now close to the frame....maybe bottoming out?
3.) The steering arms, drag link and pitman arm look original judging by the amount of dirt and grease. I wish there were better pictures available. Example of potential bump steer caused by modification?
I'm beginning to think that this was someone's project that never got completed and was sold off. It was then cheaply dropped in stance to make it appealing visually.
Ebay item 124038490328 and currently has 13 hours remaining.
Crusing in the Passing Lane
U bolts too long, that's why extra nuts, tie rod bent also.
Ed
U-bolts are fine. You are missing half of your leaf springs.
Blocks in rear are contributing to bump stop distance. I would not drive this, at least very far. Somewhat dangerous. And this is all seen in pics. Im sure in person, its going to be worse, not better... pix
Apon closer looking at the rear. Curb rash may be coming from tire actually rubbing bump stop? And the brake line appears to be directly over the axle to where if the bump stop would contact the axle, the line will be crushed... eeeee
Actually looking at the view toward the outside of the truck rather than from forward of the axle, it looks like the brake line is routed to the side of the bump stop. But still, it's not safe to drive. I see that there are no bids to date. I wonder why? wink
Oh i do see looking at the pic to the left. I was probably hoping to see some bad stuff to point out and jumped da gun.. lololol. My fault. computerdeath
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Wow nice looking truck in the ad. Hopes da buyer looks at it upside down b4 pulling da trigger..
Crusty Old Sarge
Crusty Old Sarge
The more time you spend looking at the pictures in the Ad the more you find wrong. In one of the pictures you can see fluid dripping off the exhaust
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Another has a cable for the parking brake looped around the pin and held on with a cable clamp instead of a proper clevis. No telling what the other end has on it.
Actually both sides are that way.
The tranny is leaking a bit as well.
Curmudgeon
Curmudgeon
In my e-mail to the seller, I also mentioned:
Mistakes
1.) The 235 engine was 105 horsepower not 92
2.) It did not have an oil bath air cleaner but a dry element type
3.) The "contrasting black running boards" are red in their pictures....that's got to be a bit embarrassing.
Missed selling points
1.) Air conditioning (not completed)
2.) Conversion to 12V and alternator
3.) Front disc brake conversion
4.) Later model Saginaw 4-speed transmission with $$$ Patrick's modified Hurst shifter.
5.) Later model rear axle (year and ratio TBD)
