6 members (UtahYork, GMJim, Jims46, Danielbolt, Steelonsteel, dt235sd), 162 guests, and 3 robots.
Topics128,167
Posts1,057,017
Members48,458
#1341806 01/12/2020 11:06 PM
rad
Offline
I'm 6'3 and have a hard time lifting my feet up to get to the clutch and brake pedals. would like to maintain the original look of floor pedals but am considering hanging pedals. Also considering modifying the floor pedals. any thoughts or if someone has modify pedals (pictures)
Last edited by Justhorsenround; 01/12/2020 11:08 PM. Reason: Asking for parts in the Garage Forums is not allowed
Crusing in the Passing Lane
I raised the seat on my '54 630, same cab, 1.5" and it really helped. Used two pieces of oak T and G each location.
Ed
rad
Offline
Will try that as well, good thought but I would still like to possibly modify the pedals, I would think a combination of things will make it drivable. would like to see if anyone has modified the pedals to help....thanks! I have had a few back surgeries and don't have the best feeling in my legs and feet. I'm afraid if the brake pedal is too high I may contact the side and not the top of the pedal in a quick stop.
Riding in the Passing Lane
I have cut the shaft on several brake pedals on trucks that I have had. Remove pedal & shaft. Cut it right below the pedal. Cut out the amount of the shaft to get to the height of the clutch. Weld the pedal back on.
George
1972 Chevy c10 Cheyenne Super
