8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible), 38 guests, and 10 robots.
Topics128,012
Posts1,055,312
Members48,419
#1341161 01/09/2020 4:03 AM
Was playing around disassembling the 38 dash that was removed years ago when i first took the truck apart. There was a key in the ignition switch that fits it and the door lock. It doesn't want to unlock the glove box, were there originally different keys for them or is the lock just jammed??
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
2 Offline
I’m not sure
But my 1950 Chevy had two different keys, glove box was different
And I have a 53 Chevy where all locks match
Side note
The locksmith in the closest city was able to get the codes for the locks and cut a key to the numbers in a book without needing the lock even for these old trucks.
Glove box is different key.
After several years, it seems that any key will work on some ignition switches. Some even accept a screwdriver.
Thanks guys, I've had multiple vehicles over the years that had different keys, usually one for ignition and doors then another for trunk and glove box, so i figured that was the case here too. The glove box latch is in the unlocked position so its usable the way it is. I know the trucks history as its lived in my neighborhood all its life. Started as a farm truck then went to my father in law then to me. I suspect that latch has never been locked knowing both the previous owners.
65 AC Cobra replica
USAF vet
Ive tried a bunch of old GM keys on my 37 glove box door to unlock it with no luck. guess its time for the lock smith.
1937 Chevy 1/2 ton panel
Charlie/Cletis had a locksmith's GM old-key collection.
RIP, Charlie
If you can see the 4-digit code on the lock you can have a locksmith punch/cut you a new key. Look for the oldest locksmith in town...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike, Loc Doc on 67 to 72 site cut me keys off handle no. Not sure if he could help. http://67-72chevytrucks.com/vboard/showthread.php?t=630654
