6 members (Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, Hotrod Lincoln, 1 invisible), 128 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#134132 03/30/2006 3:44 AM
Hi All,
I am sort of new here and this question might be obvious to some, but not me! How much trouble is it to put a big block in a 1952 3600? I am guessing that it is much more difficult than a small block because of the steering box and the size of the larger engine, am I right? I did a search and came up with zip, so your comments would be appreciated!
Rick
#134133 03/30/2006 4:24 AM
I do not know, technically speaking, how much more difficult it would be. I had an old f-150 for a while that had a 460 in it and darn was that thing fun!!! I would go for the BB just because of the "lope" and power. Good Luck!!!
Knox
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#134134 03/30/2006 4:38 AM
You are right. It is more difficult.
I don't think I've ever seen it done using the stock steering. The big block swaps I've seen were all power steering conversions, subframe swaps or Mustang II IFS.
#134135 03/30/2006 11:09 PM
Not sure of all the differences,but I put a 454/turbo 400 in a 1945 chevy 1 1/5 ton 4x4. Used the stock steering gear,didn't alter any sheet metal,used the original reworked radiator shell/housing and used the 454 HD fan clutch and blade. Anything can be done!
Good Luck!
#134136 03/30/2006 11:23 PM
Thanks for answering Knox, OldSub, and cprice. Such decissions to make. I am pulled between the 292, TPI 305, and a big block. I have built a 350 before, in an S-10, so I have been there done that. I think I need to do some serious tape measure work!
Rick in VA
#134137 03/30/2006 11:38 PM
No Replacement for Displacement!
#134138 03/31/2006 7:38 PM
Junior Member
Junior Member
Quote
Sure there is....forced induction. grin
'58 Apache: Camaro sub, 383 w/forced induction, 700R4 trans, 4-link w/floating 9" and un-altered sheetmetal.
#134139 04/01/2006 5:03 AM
Rick,
If you need something to pull a tape on I have my 2 ton down to the frame, and my 1 ton still driving. I know it says I am from Lexington, but my trucks are in Martinsburg WV right now. Send me an e-mail if you want to stop by and take a look.
I am in the process of putting a 4-53T Detroit and a 10 speed in my 2 ton.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#134140 04/02/2006 1:38 AM
steering box is a problem on V8....much has been said here. I am about to put a V8 in my 52 panel so the comments here will be interesting. I have been taking some notes and it seems there is a Toyota box that will bolt on the "side" of the chassis with out much hazzle.... check back on some threadsa nd I'm sure you will find it...
#134141 04/02/2006 5:53 AM
is there a problem with steering gear, putting a v8 in a big bolt 51 6400
#134142 04/02/2006 7:00 AM
As far as I know, and some one please back me up, or explain better.
The front section of the frame on all AD trucks from 0.5 to 2 ton are all very close to the same size, if not identical other than being thicker steel. Check the frame measurements in the frame section of your service manual, you will see.
So, yes, it is still the same problem as on the 0.5 ton.
Grigg
---All pictures---
