4 members (78buckshot, Wally / Montana, FishinToms53, klhansen), 57 guests, and 2 robots.
Topics128,053
Posts1,055,778
#1340563 01/05/2020 7:14 AM
[img]http://[/img][img]http://[/img] I pinched the wire for the electric fan between the grill and the fender blew a fuse I fixed the smashed wire replaced the fuse.
Electric fan won’t power up is it possible I blew up the switch as well?
This is no longer fun
Bypass switch and jumper wire it direct.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Where is the power to the switch coming from? You might have another blown fuse somewhere upstream. Check to see if power is getting to the switch before you start shotgunning parts at the problem.
Thanks Ron and Jerry I’m chasing wires right now.
Sorry for the double post forgot how to post pics
Can you run a continuity test on the switch?
Another quality post.
Real Trucks Rattle
Are you trying to control an electric radiator cooling fan with that switch? If so, you're headed for trouble in several ways. It won't have the proper current carrying capacity, and if you attempt to use the low speed circuit, that resistor wire will get red hot and probably cause a fire under the dash.
I did have the radiator electric fan hooked up to that switch with a relay
Was only using one speed on the switch high
I smashed a fan wire between the fender and grill blew a fuse now the fan quit working,
Been chasing wires .
My fan just quit. Hmmm?
Was almost home from a nice joy ride and using the heater. All was rebuilt and repainted as part of the recent restoration of our '58 Apache 3100. Had been using the heater for about 45 minutes this morning. Had heater fan on Low and stopped to wait my turn at a traffic signal. Started down the road and heard a flapping noise. First instinct was that it was a valve problem, again. Noise wasn't loud, but it quit shortly after it started.
Is this likely a switch or a motor problem? Did not see any blown fuses at the main fuse panel below the dash.
A flapping sound would indicate to me that something came loose in the box, possibly locking up the fan motor. Just a guess.🛠
Something probably got sucked into the squirrel cage blower, and either got ground up or passed through it after a while. Mouse nests usually make a squeaking noise, followed by a bad stink when that happens.
Its a squirrel cage. I would also check for squirrels. Flying squirrels specifically, as they are quite small...
Sorry, Jerry,
But in this case you and 52 Carl are neither funny or helpful. I know you can do better.
I had mice in my squirrel cage, around the heater core and just about everywhere else a mouse could fit. Fortunately, my squirrel cage was not damaged, other than a bit of rust.
Real Trucks Rattle
Originally Posted by raleigh58
Sorry, Jerry,
Exactly what do you want for nothing? Have you investigated the fan for obstructions? You have been given all of information necessary to begin to look for solutions to your mystery, harmlessly colorful as the advice may have been.
Sorry, but that is all that I have to offer from 200 miles away. If you were closer to 100 miles away, I'd help you if need be. I am certain that Jerry would as well.
Corny Carl
Thanks Jerry and Carl for attempting to help. This is a garage stored truck, driven weekly and one I doubt the mice have had time to find. Replacing the original fan motor with a new one. Checked for power at the fan motor and found none. Also no blown fuse. I believe we are on to a solution.
Keep smilin' and drivin'.
John, ridin' in NC
Good deal, John! Although it doesn't seem like it so far this winter, you will be needing a heater soon enough. February is the month of misery for us in Virginia and NC.
Hey 52 Carl. The weather took a turn this week. It's winter time in Raleigh. Highs for Monday and Tuesday hovering around 39. Brrrrrrrrrrrrrr.
34 high and 28 low today in Jarvisburg, NC
