5 members (artinva, Opelika Tom, JW51, Gdads51, Otto Skorzeny), 65 guests, and 2 robots.
Topics128,077
Posts1,055,932
Members48,430
#1341119 01/09/2020 12:13 AM
Recent 1955 lcf purchase. Are these the rims to avoid. Thanks Pat
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
Yes, they are, otherwise known as Firestone RH-5's. The 2" wide flat strip near the middle is a "dead" giveaway. The problem with these rims is the extremely narrow locking lip that holds the two halves of the rim together. It's notorious for getting rusty, or being damaged during assembly, and blowing apart when the tube is pressurized. If a wheel has been assembled and run for a while, it's probably fairly safe, but few, if any tire shops will work on them. I believe there's a DOT regulation prohibiting them from being used on commercial vehicles, at least.
Big Bolt Forum Moderator
Are you sure that is a 55 and not a 56? I thought the 6 lug pattern was not introduced until 1956.1955 should have the 5/10 pattern.
Mike
Let me check. Would the 57’s all have 6 lug also?
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
What model is your 1955-2nd series LCF, taskforceguy?
1955-2nd wheel/tire specs are shown in here. pages 165-166
1956 wheel/tire specs are shown in here. page 184
5700 with an18’boom and 30k tulsa winch. Sweet ride!
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
They only made the one LCF Series in 1955-2, the 5000 Series. The 7000 & 9000 Series weren't introduced until 1956 and with them was the start of the 6-lug Budd wheels for Chevrolet.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Great info Mike thanks. The rubber on the 55 is beyond bad but the 57’s have descent to great rubber although 6 lug axles. I’d like to swap axles and use not only descent rubber but 2 of the tubeless 22.5 up front. Hopefully they would clear the fenders
58 1 ton Napco
59 1/2 ton Napco
58 1/2 ton Napco
55 1 ton 9’ bed
58 3/4 ton stepside
55 LCF boom truck
(3) 57 2 tons
A 22.5" tubeless tire will always have an equivalent-height 20" tube type tire. They're close enough in most cases that a 20 and a 22.5 can be run as duals on the same rear hub.
What Jerry says is true as long as you remember that the number sizes don't match...the 22.5's need to be one size larger to line up with the diameter of the 20's
7.50x20 = 8.25x22.5
8.25x20 = 9.00x22.5
9.00x20 = 10.00x22.5
10.00x20 = 11.00x22.5
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Wow!, Looks exactly like the '55 model LCF, I used to own. Same color and all, only it was a 5400 series.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
