7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Have set up a early 250 c.i. to look and hopefully run like an early "Vet" 6. I have adapted/installed 4 bbl. carb, "Offy" intake, split exhaust, etc. Have aftermaket hi-dollar radiator. Question...with a "perky" 250, how high of a pressure should I run on the radiator cap? I do have a "puke" tube but don't want antifreeze all over the chrome and polished alumnium. Thanks in advance for your comments.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hey Beltfed,I would use a plastic tank connected to your overflow tube(what you call a puke tube) and a 14 lb.two way closed system cap.You can hide the plastic tank so only the hose shows.You can get the kit at any good auto parts store.A 14 lb. cap will raise your boiling point with a 50/50 mix of antifreeze to approx 259 degrees and keep the overflow contained.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | What about setting an overflow tank inside the frame rail,just behind the core support? That way you can run the overflow hose down to it and people will mostly assume it vents outside,somewhere below the frame. Speed | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | How can you tell if you have a 2/way cap? my overflow tank stays dry. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | It has a valve(flapper)in the center to let the coolant be sucked back into the radiator as it cools.Should also say closed system on the cap and the pressure it blows off at.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Thanks, I will look today. Like I said, I installed a overflo tank but never even gets damp. Have a 14lb cap on now, aluminum radiator and pump, all good condition should I lower it? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | No,I wouldn't with a new system.I have seen some Chrysler systems with a 16 lb cap.Put some coolant in the tank and see if it sucks it back into the radiator after it is run then cools off.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | will try as soon as the weather in michigan permits. thanks | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | p.s. I do have a 2 way cap but will be unable to fire the thing this week. | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | Don't forget the heater core. Early heaters were only made for 2LB presure and even a later used heater won't take a lot of presure. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Good point Lugnut!You are right about that.
