| | | Forums66 Topics128,282 Posts1,058,490 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13409 04/26/2005 10:43 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Interested in hearing what you guys think about these two IFS...is there much difference between the two? would like to hear any and all comments.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#13410 04/27/2005 11:56 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | After 2-1/3 years, four seasons, and 25000 miles on fine Chicago roads, I'm still happy with my Progressive Automotive MII IFS kit. No complaints, no problems. http://www.homestead.com/chuckthetruck/page2.html | | |
#13411 04/27/2005 1:05 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Dont know about the Pacer.I put the TCI M2 in my 55,and I am very happy with it. | | |
#13412 04/27/2005 1:29 PM | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | a freind of mine used the pacer and was not happy with it at all. drove the truck for about 2 months and sold it got a different one to work on. have not talked to him lattly he moved out to ny state..mike j | | |
#13413 04/27/2005 2:53 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have the pacer, have had it installed for about 18ys. leaks like a cieve and i don't know what to do about it. i would stick with the mustang. easier parts find and repair. maybe a little more expensive to start with but cheaper in the long run. it has worked fine other than leaks. i have been told it is a problem with them. i put it on long before the mustang became popular, now you can find the mustang everywhere. IMHO ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#13414 04/27/2005 3:16 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I have a stock (not aftermarket) Mercury Bobcat (Pinto/Mustang II)IFS in my '52 Burb...I had to replace the coil springs with heavier coil overs, other than that it rides and handles great. | | |
#13415 04/28/2005 1:53 AM | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Pacer on mine (54 PU), cheap out of a boneyard--original rack leaked, replacement has been fine for the five years it's been on there, you just have to take care of it. Steering, suspension and brake parts are cheap and readily available. Secret to good handling with the Wayne's World front end is appropriate springs. Good suppliers will sort this out for you. But everyone I've spoken to with the MII setup is happy with that too, particularly the lucky ones who can afford the setups from TCI, Progressive etc.
Also depends on whether you want to cut the frame off. MII you have to (I think--others will correct me if I'm wrong), Pacer you don't. Makes for an easier fix. Also I kind of liked keeping my frame in one original piece. And my dosh in my pocket. Most of the fancy MII setups cost blood.
Christian | | |
#13416 04/28/2005 12:31 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | what I'm hearing is that if ya got the $$$ the mustang II would be the way to go. Don't want to start cutting on the frame and I have a hard time shelling out as much as I paid for my truck originally though. I have heard from others that the Pacer steering racks leaked but seems like cheap/good replacements are out there and the price for the whole shootin match sure fits my budget...
Blue 50
#13417 05/15/2005 2:39 AM | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | I put a M11 under my 37 but didn't cut the frame. I paid 75 dollars for all the A-arms, rack and pinon for a core to buy a new one, used the spindles and all. My welding friend plated the side of my original frame, welded in the cross member and sping towers etc. I put in new ball joints,shocks, and bought after market rotors with chev bolt pattern to fit the stang spindle. No problems so far and the hardest part was taking the stang parts off in the junk yard with it raining!! Been running Good for 6 years. | | |
#13418 05/15/2005 5:48 AM | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | The early Pacer racks leak but they fixed the probby with the later ones so they don't. Guy with an MII under his truck told me the Pacer setup is more robust but I've no idea if that's true. Personally that particular iteration of the Mustang gives me the creeps, it's such a hairdresser's car. I'd never insult my truck with so much as a spring washer off one of them. Or anything off any Frod, come to think of it. (Sole exception: the 9 inch rear end.) Whereas (a) the Pacer's kind of a nice joke and (b) Teague was a genius who was probably on acid. (The Mustang II was designed entirely by a committee of pinheaded bean-counters.) Not that there's any practical use to you in either of those observations. I guess if you're less prejudiced than yrs truly the MII would be the choice if you can get it all done super-cheap. If only because it's more modern and when you tell people what's under there they won't go blank like when I tell them mine's all Pacer. But to me it's still a piece of Frankenstein monster gut. Sorry to go on. | | |
