1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#1340432 01/04/2020 3:10 PM
Working on getting the parking brakes working on my 1954 3100. Cables are replaced, but the lever inside the driver side rear drum is broken. The tab that makes a ā€œUā€ around the cable was cracked and broke off in my hands. My usual sources are LMC or Jim Carter and I do not think they sell them. Any one know of a reproduction or can someone help me out with a part number?
Thanks in advance
BB
Bryan
1954 3104 235 "AD" L-6 3-on-the tree
!956 Gmc Napco 4x4 Factory line built .
Cannot find it there.
I can always try to repair it, but do not own a welder so I figured I’d try to replace first.
BB
Bryan
If you can post a picture in the parts wanted forum, one of your fellow bolters may have one lying around. Possible you local high school has an auto shop class that could help.
Ed
' Offline
BB,
The original GM part # for the Drivers Side Rear parking brake lever - Group # 5.149
GM # 3693603 LEFT ( drivers side ) & the Right - 3693604
The ( 2 ) above GM part numbers were superseded to : GM # 3820159 Left & GM # 3820160 Right
GM # 3693603 Left Side was used on 1951 to 1958 Chevy 1/2 Ton Trucks &
1951 to 1957 Chevy passenger cars .
1953 & 1954 thru 1957 Corvettes ALSO used the SAME parking brake levers as the 1/2 ton truck .
Here's a Corvette Repro parts seller that sells repro brake levers
https://www.corvettecentral.com/c2-...mergency-brake-lever-kit-includes-191097
PIC
https://i.postimg.cc/ncyFxfg8/Parking-Brake-Levers-replaces-GM-3693603-LEFT-and-RIGHT-3693604.jpg
You can re-use your original hold down bolt , spring washer , lock washer & nut .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
