| | | Forums66 Topics128,190 Posts1,057,223 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 52 | Are there major differences between the '55-'59 half ton rears and the '60-'66 half ton rears? Brakes? Center section? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955-62 use the same center section. 1955-59 had leaf springs, 1960 and later used coil springs.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 52 | Thanks. Sounds like I can probably use a rear up to '62 since I just want the center section and brakes/backing plates fir my '46. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I took a ‘62 3.90 gear set and bolted it right into my 1953 housing. I didn’t gain much ratio but did get open driveline. Gotta love GM LEGO pieces, hey?! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Like Fox mentioned, a 1955-62 center section will bolt right in a 1940-54 truck axle housing. The bendix brake swap is not so easy, easier to change the housing. I will add that having Huck brakes on the back is not a bad thing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2005 Posts: 125 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 125 | So an open driveline 55-62 1/2 ton third member will bolt into the earlier 54-49 axle housing? What about the axle shaft splines? Do they match the internal side gears from the 55+ third member? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2005 Posts: 125 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 125 | Wow, that makes an open driveline a simpler possibility. What are some transmission combinations? Will a 3 speed from the 55-66 model work with the 2 shifter arms & linkages fron the original style? | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You will need later bellhousing (48 up) to use a 55 and later transmission. I'm not sure what type side cover/linkage configuration a 46 has. The 55 transmission has a 4 bolt side cover. The 1/R shift fork has to be replaced on an AD truck to use the side cover on later trans. Yours may be similar. A 3 speed overdrive transmission would be a good option. Fred
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | To be accurate you would need a 1948-53 truck bellhousing to accept the later transmission and correct bellhousing mounts. Since a 1946 is floor shift, you would need an aftermarket floor shifter for a 1955- trans.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | That confused me as well when I responded, I guess I thought he had some later column shift configuration. Fred
