0 members (), 100 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
Are there major differences between the '55-'59 half ton rears and the '60-'66 half ton rears? Brakes? Center section?
1955-62 use the same center section.
1955-59 had leaf springs, 1960 and later used coil springs.
My Blog
Thanks. Sounds like I can probably use a rear up to '62 since I just want the center section and brakes/backing plates fir my '46.
Fox Offline
I took a ‘62 3.90 gear set and bolted it right into my 1953 housing. I didn’t gain much ratio but did get open driveline. Gotta love GM LEGO pieces, hey?!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Like Fox mentioned, a 1955-62 center section will bolt right in a 1940-54 truck axle housing.
The bendix brake swap is not so easy, easier to change the housing.
I will add that having Huck brakes on the back is not a bad thing.
My Blog
6 heaven
6 heaven
So an open driveline 55-62 1/2 ton third member will bolt into the earlier 54-49 axle housing? What about the axle shaft splines? Do they match the internal side gears from the 55+ third member?
Same splines
My Blog
6 heaven
6 heaven
Wow, that makes an open driveline a simpler possibility. What are some transmission combinations? Will a 3 speed from the 55-66 model work with the 2 shifter arms & linkages fron the original style?
You will need later bellhousing (48 up) to use a 55 and later transmission. I'm not sure what type side cover/linkage configuration a 46 has. The 55 transmission has a 4 bolt side cover. The 1/R shift fork has to be replaced on an AD truck to use the side cover on later trans. Yours may be similar. A 3 speed overdrive transmission would be a good option.
Fred
To be accurate you would need a 1948-53 truck bellhousing to accept the later transmission and correct bellhousing mounts.
Since a 1946 is floor shift, you would need an aftermarket floor shifter for a 1955- trans.
My Blog
That confused me as well when I responded, I guess I thought he had some later column shift configuration.
Fred
