1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Ok so I got a 28 chevy and am pretty sure I'm gonna box it. Question is, if I use the existing front axle, is there aftermarket stuff to make it disc brakes and PS. Haven't seen the car yet, bought it on ebay and my dad is bringing it home from Fla. http://cgi.ebay.com/ebaymotors/1928...31037QQcategoryZ6173QQrdZ1QQcmdZViewItem Anybody do anything this old that I could pick their brain??  thanks Jim | | | | | Joined: Dec 2004 Posts: 56 Member | | Member Joined: Dec 2004 Posts: 56 | howdee Jim... glad to see you're working on the '28... they are beautiful Chebbys.. i'm working on a '35 chevy pickup... i'll be using the disc brake adapters from ECI and i'll be choosing my other brake parts a little later on... (they have a great catalog giving quite a bit of technical advice which i found to be quite helpful).. for power steering i'll be using a Toyota 79-85 straight axle 4x4 steering box which i'll adapt to a early 90's monte carlo tilt column... i plan to retain my straight fron axle but i'll be using an S10 2wd rear axle... since your frame is similar to mine perhaps these ideas could be somewhere to start... i had to dig around a bit to come up with this... i'll be happy to help out anyway i can... Bill W. in Virginia | | |
