2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#1340086 01/02/2020 3:13 PM
Has anyone rebuilt the gear/crank assy.on the window regulator? I have the part ordered . I'm assuming I need to grind off the 4 factory rivets and re rivet the new one on however are there any tricks/tips on getting the large spring off/on? With the minimum amount of bloodshed!! John. Thanks. By the way it's a 49 gmc
1949 gmc 1-ton
Vicegrips and patience for that big spring. 3 or 4 extra hands would help.
Johnny N #1340230 01/03/2020 12:01 PM
Ok thanks. we ll give it a try. I'll have bandages handy
1949 gmc 1-ton
Johnny N #1340233 01/03/2020 12:15 PM
Its been several years since I messed with a regulator, but IIRC we used to clamp the assembly in a vise to maintain the spring pressure. Above all, BE CAREFULL! John
Johnny N #1340234 01/03/2020 12:25 PM
By the looks of it appears to have a fair amount of pressure. Just don't want it flying off into some vital body part in the process. I ll watch myself. Thanks
1949 gmc 1-ton
Johnny N #1340357 01/04/2020 12:12 AM
If one is successful with installing that big spring on the first attempt, one is entitled to having one's Man Card stamped.
Johnny N #1340360 01/04/2020 12:19 AM
They ll probably be revoking mine!!
1949 gmc 1-ton
Johnny N #1340361 01/04/2020 12:20 AM
This truck is trying to kill me one slice at a time
1949 gmc 1-ton
Johnny N: I did mine about 5 years ago and as per the other replies: clamp it in a vice, wear safety glasses, be careful. I can’t recall the details of fighting that spring other than that it wasn’t impossible: just used some small pry bars/screw drivers to leverage it off and back on. As for splitting the body apart you can drill out the rivets, and upon reassembly I used small machine screws and nylocs to hold it together. (See attached photo).
Good luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Excellent advice guys. Thank you for the pic too.
1949 gmc 1-ton
Fox Offline
I second the glasses. Put on a face mask too. Teeth are expensive to replace. I have 2 implants now and a bridge. Stupidity doesn’t care how much something costs, put on your gear.
I always ask myself before I’m about to grind, buff, zip, “Do you want to know what your kids will look like when they are grown up?” On goes the gear. It’s funny how my invincibility has disappear since my kids arrived. I wish they would have come sooner, I’d likely still have those teeth.... 😜
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Moderated by  ndkid275, Phak1
