0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | I have an assortment of sealants, threadlockers, epoxies, etc. that are used on an occasional basis. Today, I went to use a red threadlocker and found that it 'weeped' out of the original sealed tube for no apparent reason. The major brand name materials I have are all less than three years old and have been carefully stored so as not to subject them to freezing temperatures. Perhaps, I just don't use enough of these materials and I recognize there is a reasonable 'shelf life'(older product = longer curing time), but I hate to purchase another tube from project-to-project.
I have a few questions:
How are you storing these materials?
Do you have confidence that a product will perform as intended for weeks, months, and years?
Do you discard opened tubes after a year or so?
Any other thoughts or comments on this subject would be appreciated, thanks.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We use a refridgerator for storing all our chemicals; the cool slows down the reaction. Partial tubes of caulk are helped the most. A second box that used to be a small camper fridge has a light bulb in it to keep welding/brazing rods dry. DON'T keep food in with the chemicals.
Evan
| | | | | Joined: Jul 2004 Posts: 2,990 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,990 | I've noticed, with silicones in particular, that the cap on the tube will split open for no apparent reason. Once that happens the stuff will of course dry up and be worthless. Why those caps fail I have no idea. | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | I've started buying thread locker in small foil pouches- - - -just enough for one job and discard the leftovers, which usually isn't more than a few drops. Even if two pouches are needed for a big job, the cost savings is considerable. Silicone anti-seize for rubber spark plug boots and heat-conducting dielectric compound for ignition modules is sold the same way. Brush-on gasket sealer like Permatex Super 300 seems to last forever as long as it capped snugly. Jerry
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | For the thread lock in plastic tubes, I drilled a 6" long piece of 2x4 with holes almost through and stand the tubes in the holes. If I lay them on their sides, they leak that sticky mess. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | I use loctite thread loc in lips stick style tubes .Great never leaks and is good for a very long time. I have red, blue ,green some over five years old,still the same as when new.
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Jan 2020 Posts: 5 New Guy | | New Guy Joined: Jan 2020 Posts: 5 | We use a lot of loctite on the ranch. Have blue, red and green sleeve retainer in the "big" bottles. No special storage, just room temp on a shelf. Products are nit over 5 years old and still work fine. Just keep the cap on to seal the bottle.
Silicones are best used quickly. They all seem to dry out once they are opened.
Antiseize....that stuff seems to last forever, especially Catapillar brand. | | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Thanks for your replies. There are some good purchasing, usage, and storage suggestions we can all benefit from while using these products. | | | | | Joined: Apr 2016 Posts: 1,051 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,051 | I like the stick form. It seems to last forever and not near the mess. Also the gel form is nice for inside threads. I am using all stainless fasteners. The anti seize in stick form is a godsend
