| | | Forums66 Topics128,109 Posts1,056,260 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | Gentlemen: I have a 51 1/2 and want to mount the rear shocks "inboard" of the frame so I can install larger tires and rims. Anyone make a kit for this with the stock springs????? Thanks, Tom
1951 Chev.P.U. Streetrod-project 1951 Chev cpe 261 5-speed-50% 1953 Chev cpe 350/700-95% 1962 Chev Bubbletop 409 -75%
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I am not sure what you mean by inboard but if you are talking about mounting them inside of the frame then these pics show how we made our own mounts and put shocks on my 46 chevy truck using the stock springs and helper springs with a rearend from a 69 montego. rear end1 rear end 2
1946 Chevy Pickip
| | | | | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | zipper: Yep, that's what I mean. Thanks for the pics. They help!
Tom
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Before you invest in a kit that may or may not fit your needs...be advised that your local trailer repair shop sells perches, u-bolts and mounting plates at a greatly reduced price. I purchased the entire setup to perch and secure a camaro diff for $20. That way you can add an ear for your shock mount where ever you need it. I've found that the generic kits are just that....generic, and usually wind up hanging on the wall. Just my $.02.....gained from.... | | | | | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | Fla54Chevy3100 Excellent $.02....!
Thanks, Tom
