6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
Apprentice
Apprentice
Gentlemen:
I have a 51 1/2 and want to mount the rear shocks "inboard" of the frame so I can install larger tires and rims. Anyone make a kit for this with the stock springs?????
Tom
1951 Chev.P.U. Streetrod-project
1951 Chev cpe 261 5-speed-50%
1953 Chev cpe 350/700-95%
1962 Chev Bubbletop 409 -75%
Z
Z Offline
I am not sure what you mean by inboard but if you are talking about mounting them inside of the frame then these pics show how we made our own mounts and put shocks on my 46 chevy truck using the stock springs and helper springs with a rearend from a 69 montego.
rear end1
rear end 2
1946 Chevy Pickip
Apprentice
Apprentice
zipper:
Yep, that's what I mean. Thanks for the pics. They help!
Tom
Before you invest in a kit that may or may not fit your needs...be advised that your local trailer repair shop sells perches, u-bolts and mounting plates at a greatly reduced price. I purchased the entire setup to perch and secure a camaro diff for $20. That way you can add an ear for your shock mount where ever you need it. I've found that the generic kits are just that....generic, and usually wind up hanging on the wall. Just my $.02.....gained from....
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Apprentice
Apprentice
Fla54Chevy3100
Excellent $.02....!
Tom
