1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#133983 03/06/2006 9:38 PM
Junior Member
Junior Member
What is a subframe? I see "subframe" posted all over the stovebolt forums but never a clear definition. Appearently a subframe can cure everything from bad breaks and steering to ride hight and comfort. Can I go to the junk yard and request a subframe? I have a 55 1st series 3100 with a V8, what "subframe" should I be looking for? Wanting to make a driver to use as a truck, no show but prefer the stock look.
#133984 03/06/2006 10:19 PM
A subframe is the front frame stub on a unibody car that the suspension, engine, transmission, body, etc bolts to. Unlike a full frame car, a unibody relies on the body of the car (ie. reinforced sheetmetal) to link the front subframe to the rear subframe. Some hot rodders cut the existing front suspension off of their full frame vehicle(non unibody) and weld on a subframe from another vehicle (camaro,etc.) In your truck's case, you could take a 70's camaro subrame, cut the front of your existing frame off and weld the camaro front end to your 1955 frame. This would gain you independent suspension, V-8 motor mounts, transmision mounts, and probably a lower ride height. It's a lot work and it can yeild unpredictable results if it is not done with a lot of carefull measurements and competant welding.
#133985 03/06/2006 10:27 PM
Amen, not a job for a novice. I made it but struggled
#133986 03/06/2006 11:39 PM
Bobby, here's a pic of a Camaro clip "subframe" that's welded on a 2"x4" tubing and a Camaro rear end. This will be for a '55/2-'59 short bed pickup.
Pic
#133987 03/07/2006 3:30 AM
#133988 03/07/2006 5:20 PM
Junior Member
Junior Member
Thanks for all of the information and pictures, it appears I have more research to do before making a final decision.
Thanks again
