7 members (NJC, David Bush, Oswald, Otto Skorzeny, GRNHydra, 2-Ton, Rusted Nut),
76
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Have refurbished the rear shocks, new end cap seals, modern seals on the arms,one shock seems easy to pull down the the other is hard. Does the orientation of the small spring/valve under the filler plug effect the rate of flow therefore making the shocks harder or softer? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Your Images will not open. Follow instructions "Posting Images" in the lower left-hand corner.
Harold Is a restoration ever finished? | | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | The images are of the truck only,any one know the answer to the querry above? | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | How did you pull the arm off the shaft? A couple of these on my '41 need new seals and pulling the arm off looks difficult, little room to get anything behind it.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Visit Apple Hydraulics website. They rebuild a lot of knee action shocks.They are easy to work with.
Ed
| | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Hi Harold A mate pulled the arm and shaft out in one piece He drilled a hole on the opposite side to the arm and pressed the hole peice out
After the new seals were installed the hole was welded up | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Thanks, I may try that later this winter. Being a cheapskate I'm hesitant to pay $185 per shock.
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Harold --I have 2 rear rebuilt 40.00 plus frt--Bill | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Selling in the Forums is prohibited. Please move to Private Message. Thanks
