0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1339667 12/30/2019 4:02 AM
Have refurbished the rear shocks, new end cap seals, modern seals on the arms,one shock seems easy to pull down the the other is hard. Does the orientation of the small spring/valve under the filler plug effect the rate of flow therefore making the shocks harder or softer?
Your Images will not open.
Follow instructions "Posting Images" in the lower left-hand corner.
Harold
The images are of the truck only,any one know the answer to the querry above?
Don't know the answer but maybe you can figure it out from here...
http://chevy.oldcarmanualproject.com/shop/1942/42csm0206.htm
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
How did you pull the arm off the shaft? A couple of these on my '41 need new seals and pulling the arm off looks difficult, little room to get anything behind it.
Harold Wilson
41 Chevy 3/4 Ton
Visit Apple Hydraulics website. They rebuild a lot of knee action shocks.They are easy to work with.
Ed
Hi Harold
A mate pulled the arm and shaft out in one piece
He drilled a hole on the opposite side to the arm and pressed the hole peice out
After the new seals were installed the hole was welded up
I may try that later this winter. Being a cheapskate I'm hesitant to pay $185 per shock.
Harold Wilson
41 Chevy 3/4 Ton
Harold --I have 2 rear rebuilt 40.00 plus frt--Bill
Selling in the Forums is prohibited. Please move to Private Message. Thanks
