2 members (Otto Skorzeny, 1955 1 Series), 89 guests, and 4 robots.
Topics128,031
Posts1,055,436
Members48,422
#1339417 12/28/2019 5:49 AM
After years of choring in the mud with chains on it, the right rear brake drum on my 35 1.5 ton is in bad shape. The keyway is badly egged. Off the top of my head I think there are about five washers under the nut to get it on tight (with a 16 penny nail courtesy of my uncle). The axle isn’t pristine, but it would be fine if the drum couldn’t rock back and forth.
Does anyone have a rear drum that is in decent shape? I still use the old truck everyday to chore and run to pastures, but it’s not abused feeding silage like it used to be. I’m not worried about turning it or anything - I just want a decent drum with a good keyway.
Notjustair #1339494 12/29/2019 12:12 AM
3B Offline
Hy Notjustair, I have a 1936 one and a half to chassis, it has full floating axles. Could you possibly post a picture of your rear axle, it sounds like you have a semi-floating rear axle?
Notjustair #1339512 12/29/2019 2:10 AM
To help in your search ALL 1-1/2 ton trucks from 1931 thru 1940 (exc. COE) use the same rear brake drums, p/n 377964.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3B #1339533 12/29/2019 5:41 AM
Yes, it is semi-floating. From reading the old Chevy bulletins it is my understanding that they went to full floating in 36 with the brake upgrade.
Notjustair #1339632 12/30/2019 1:42 AM
Just curious, does your '36 truck have mechanical or hydraulic brakes?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1339672 12/30/2019 4:51 AM
I assume you mean mine - my 35 has mechanical. Nothing has been changed on it - still the same way grandpa bought it back then. Except for lots more battle scars.
Notjustair #1343308 01/23/2020 3:30 AM
Early '36 1-1/2 ton trucks used the same mechanical brakes as the '35. I think they had the full floating rear axle. I have not seen one but I have a first edition 1936 Truck Owners Manual which states that the 1-1/2 ton trucks had mechanicals.
I sent a PM to Notjustair. I have a NOS tapered axle hub for his '35 truck.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
