6 members (baldeagle, frogfarmer, Brian Moore, kades51, Hotrod Lincoln, 1 invisible), 30 guests, and 10 robots.
Topics128,020
Posts1,055,345
Members48,419
#1338939 12/24/2019 6:52 AM
i have a 1952 gmc with 15 inche split rims , tres are 700/15. i would love to keep a narrow tire as these are but get rid of split rim. does anyone know where i could start to look to find rims. thankyou for you have,
the best season to you all , and thankyou
mikebrou #1338975 12/24/2019 3:36 PM
3B Offline
Hy mikebrou, could you tell us the size of your truck or at least the number of nuts retaining each wheel? Merry Christmas.
mikebrou #1339008 12/24/2019 7:29 PM
my apology , its a three quater ton long box , six studs. i keep looking but never fine any. thanks 3b
mikebrou #1339141 12/25/2019 10:51 PM
https://www.wheelvintiques.com/artillery-bare-finish.html
Have you looked at either of these? Not sure if Artillery rims are correct on an AD. They likely have others in the same size and bolt pattern.
mikebrou #1339142 12/25/2019 10:57 PM
mikebrou #1339241 12/27/2019 12:27 AM
Six studs? You sure that it is not a 1/2 ton long box? GMC did make such an animal. A 3/4 ton would have 8 lugs.
mikebrou #1339243 12/27/2019 12:38 AM
A 1952 GMC 3/4 ton might be a different animal from a USA 3/4 ton GMC?
mikebrou,
- what is your model number?
- what is your engine? (do you think it is original?)
Here is some information from Rob English.
mikebrou #1339255 12/27/2019 2:06 AM
Crusing in the Passing Lane
If it is a Canadian truck, probably engine SN, aft of distributor, does not start with displacement.
Ed
mikebrou #1339266 12/27/2019 3:37 AM
can thank you all for your replys and will answer you all afetr this not.my truck is all original did i blew motor its a usa truck bought in las angeles by my uncle in 1952. its a 228 motor 102-22c. all i know its a long box andlong drive shaft with double ball joint and extra leaf set at rear. i was late replying because of christmas hope you all had a good time.
tc leterman and 46 in progress and edpruss thankyou so much 46 im going to look at the addresses you sent me now then let you know ty so much
mikebrou #1339267 12/27/2019 3:46 AM
just looked up serial number 102-22c 8340
mikebrou #1339268 12/27/2019 3:52 AM
so solved 102 is half ton 22 is 228 motor thankyou tcleterman now i know for sure i have a long box half ton.explains 6 stud wheels 52 carl you were correct and 46 inprogress i love the 15 inches smoothes and will phone them friday and see what they have. thankyiu wish you the best in new year. ill keep you posted
