Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 38 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#1338909 12/24/2019 1:10 AM
I bought a 261 and SM420 today. I’m trying to figure out what year the 261 is. The casting numbers are pictured below. Any help deciphering is greatly appreciated.
Tony292 #1338919 12/24/2019 2:00 AM
The head is a later 261, 56-62 head with an 86.2 cc combustion chamber. If you remove the valve cover, the casting date will be right there and you can pin it down even further.
Mike
Tony292 #1338921 12/24/2019 2:52 AM
3759365 is a 1959 block.
Tommy
59 apache 1/2t
261 short stepside
Tony292 #1338951 12/24/2019 12:55 PM
Bond Villain
Bond Villain
If you show us the other casting numbers on the block (below and aft of the distributor pad), we can tell you the exact year and month the block was cast. Here's an example
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Tony292 #1338957 12/24/2019 2:06 PM
John Milliman #1338995 12/24/2019 5:51 PM
I’ll have to remove the starter to see that number there’s a lot of crud in that area.
Tony292 #1339036 12/24/2019 9:14 PM
Did some more scraping and found k68 at the starter, is this November 6, 1958?
Tony292 #1339038 12/24/2019 9:28 PM
Yes, I think.
Wait to hear from others.
Tony292 #1339084 12/25/2019 4:56 AM
I forget now if they skipped the letter “I”. If so then it would be October 58. Either way it’s a block for the 59 model year.
Mike
Dragsix #1339162 12/26/2019 1:47 AM
Good question, I know they used "I" (eye) on the chassis serial numbers for September, I can't confirm if they used "I" on the engine casting date codes... but something in my old memory is saying they didnt...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Tony292 #1339237 12/27/2019 12:14 AM
OK, someone needs to end this thread with an "Aye aye." for it to truly to be resolved. smile
Tony292 #1339254 12/27/2019 2:02 AM
An I or an eye, and for a 1 and maybe for a lower case L (l)?
