| | | Forums66 Topics128,113 Posts1,056,580 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 53 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 53 | Have 2 issues I need advice on. Project is a late 1949 GMC 101 half ton
Door alignment.
Both doors have the same issue. The gaps are good on both front and back edge. The top of the door is nice and tight to the body. However the bottom on both doors are sticking out approx. 1/2" . Pass door is a little more pronounced. There doesn't seem to be an adjustment that will address just the bottom edge.
Door latch and striker adjustment.
On the pass door the latch will not catch on the full close position. It will catch on the safety mid point . If I really slam it 1 out of 10 times it will latch. Both the latch and striker are new repos. Ironically on the drivers side door I was able to save the latch and only had to replace the striker. This door works fine (except for the alignment issue mentioned above).
Any suggestions or links to alignment procedures would be appreciated.
Thanks, Tom | | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | Tom, one bit of hard learned advice, scrap the repo latches and find some useable orignals.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | Is the belt line on the door aligned with the belt line on the cab? A good tip that I have learned for adjusting doors is to completely remove the striker. It just gets in the way. Once the door is adjusted to the opening with the belt line aligned, the striker will usually be east to install and adjust. Carl
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Mar 2017 Posts: 53 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 53 | Thanks for the great advice. Will be checking the belt line the next time out in the garage and the start to look for NOS strikers.
thanks again Tom | | | | | Joined: Jan 2020 Posts: 96 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 96 | I have the exact same issue with my 1950 model 3100.. I just bought a service manual and it said to loosen the bolts for the door hinges. The cab side and the ones on door side.. Both sides of the hinges have some adjustment room. When the weather here improves a bit I plan on removing the door strike and loosen those bolts and see if I can't get it to fit like it should.
Colton Kenshol Hermiston, Oregon
1950 Chevy 3100 216 Motor Mostly Original..
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brad, do you have a similar set of instructions for the later A-D striker plate (catch and latch)?
Or, would the instructions be the same? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Tim,
I have never seen a filmstrip or manual like the above for the later cabs. They are substantially different in latches, strikers and even the attachment hardware and shim sets, thus they require a different adjustment approach. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I thought so, Brad
Thanks for the information/confirmation. | | |
