Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, UtahYork, 66flea), 163 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#133863 02/19/2006 5:26 AM
Junior Member
Junior Member
channeled 7" on the frame, and moved back 20"
more
drastically shortened the bed
the view that most will see ... my 60's chevy Positraction.
custome pipes to clear the cab
It started as just replacing the stock ball
bearings & king pins, it turned out into a disc convertion. not really sure how that happened.
~Mykk
#133864 02/19/2006 5:15 PM
Nice pics. Is the top chopped to?
MV
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#133865 02/19/2006 5:18 PM
Looks like that's going to be a fun ride!
38 original
48 panel
59 stepside
46 in the back forty
#133866 02/20/2006 3:41 AM
cool truck looks like fun
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#133867 02/20/2006 7:34 AM
Junior Member
Junior Member
"Nice pics. Is the top chopped to?
MV"
not yet, I'm talking to a guy who's gonna chop it 4.5 -5" for me... pretty drastic.
#133868 03/09/2006 8:32 AM
Junior Member
Junior Member
has anyone ever seen this before? when my front wheels are straight they are perfectly parrallel. but once they are turned all the way eith one direction or another the wheel closest to the direction it's turning has a more drastic angle than the opposite side... it does this on both wheels going either direction. now this truck is a frankenstein...and I do believe that front axle is from a 49 up chevy and someone narrowed it.
[img]http://i40.photobucket.com/albums/e227/mykk/wheelsturned.jpg[/img]
#133869 03/09/2006 3:40 PM
built for a dirt track,,,,,,,,,,,,,turn left grin
nice ride,, wished I owned it,, how does it drive?
Fred
Redryder pix
My Hotrod
#133870 04/15/2006 7:44 PM
Interesting vehicle... i like the A/C unit too...
Another quality post.
Real Trucks Rattle
#133871 04/15/2006 9:46 PM
Quote
Its called 'Ackerman' and if you think about the circles the tires follow going around a corner it makes sense that the inner tire is making a tighter circle.
I can't tell if the amount is correct, but the fact it happens is designed into nearly every car and truck made.
#133872 04/16/2006 3:30 AM
You'll have to take it to an alignment shop to know if it's done right or not. It's just more noticable on your truck because of the lack of fender and body,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
