5 members (2-Ton, Ponchogl, 32Fordpuchoptop, dt235sd, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,674
#133854 02/16/2006 10:15 PM
Guys do you need an after market firewall and floor if you are going to install a V8 or is that only for auto trans.
Why do I always do it the hard way????
#133855 02/17/2006 3:36 AM
neither,ihave a 350/350 combo in my 49 with no problems no mods to firewall or floor. check the motor mount and trans mount kits from chassis engineeering in iowa . both should run you about $160.00 they are bolt in with good measurements and clear instructions.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#133856 02/18/2006 3:30 AM
Dave, will look to see if they have a web page, forgot to mention its a 51 chevy 2 ton, but thanks none the less Dale
#133857 02/18/2006 10:03 PM
