30-40s up toTwo ton gear box, Does it have a bowtie in the casting?
1953 Chevrolet 3100 261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY Gallery Video of the 261 running
1964 GMC 1000 305 Big Block V6, sm420, the next cab off restoration
Have the seller take the top off and send you a picture of the gears inside...without the shifter it's open to the elements and critters.
Mike B
I noticed that as well. Even with the shifter on open to the environment, those transmissions will fill with water rendering the transmission to scrap.
