4 members (Otto Skorzeny, 3B, JoergK., 1 invisible), 77 guests, and 5 robots.
Topics128,181
Posts1,057,172
Members48,465
Apprentice
Apprentice
First off, I did do a search, but did not find exactly the information I was looking for.
My 51 has an 8 lug rear axle that was mounted under the springs. I am replacing that rear with a standard 10 bolt passenger car rear to gain better gearing and 5 lug pattern. While I'm at it, I want to lower the truck. I'm leaning towards flipping the axle to mount on top of the springs, but there doesn't seem to be enough clearance with the frame to do this. Will I need to c-notch the frame if I go this route?
Secondly I found something you guys might find interesting. These lowering blockes are adjustable, and may be just the ticket to centering the wheel in the fender opening. It certainly would be the easiest solution to the problem that I have come across. grin
http://www.speedwaymotors.com/xq/aspx/display_id.2153/qx/Product.htm
Cool blocks.
Almost as easy as springs with the pin offset, like you can get from Eaton Detroit Spring.
Cheers,
mark.
'51 KY 3100
Apprentice
Apprentice
Yes, new springs would also do the trick, but the blocks are only $60 for the pair. Of course it all depends upon your overall goals I guess.
Back to my main reason for writing this post, can anyone provide help on the process of lowering the rear? Maybe some links? I'm a visual person, so pictures would help!
grin
Thanks guys!
