| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I know I'll get some suggestions to search for the answer to this question but...been there...done that. Found lots of information on under bed tanks, but not exactly what I'm looking for. I would like to remove an after market tank from the bed (original tank removed from cab and after market 50 gal bed tank/tool box istalled by PO) because it traps trash and water and promotes rot on the bed wood. Has anyone installed an under bed tank in a '63 C-10 fleetside between the rails and in front of the rear axle? It looks like I can get a saddle tank of some kind on the right side (dual exhaust will soon run down the other side) but I haven't had any luck locating dimensions on later model vehicle saddle tanks. If there is anyone else out there that has done this, did you have to re-arrange the emergency brake cables? If so, how?
Thanks in advance. | | |
