I know I'll get some suggestions to search for the answer to this question but...been there...done that. Found lots of information on under bed tanks, but not exactly what I'm looking for. I would like to remove an after market tank from the bed (original tank removed from cab and after market 50 gal bed tank/tool box istalled by PO) because it traps trash and water and promotes rot on the bed wood. Has anyone installed an under bed tank in a '63 C-10 fleetside between the rails and in front of the rear axle? It looks like I can get a saddle tank of some kind on the right side (dual exhaust will soon run down the other side) but I haven't had any luck locating dimensions on later model vehicle saddle tanks. If there is anyone else out there that has done this, did you have to re-arrange the emergency brake cables? If so, how?
Thanks in advance.
Daily Driver 63 C-10 LWB Fleetside
