7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible), 76 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
The attention to detail paid off reading several members instructions over and over to get every detail correct, took my 54 half ton Hydramatic out for a drive two or three times and she just gets better each time, well worth the money and the effort.
Did mine a few years ago. Best thing I did to the rig. You will enjoy the higher gears.
Craig
Moderated
Moderated
Hi posey and cmayna , I'm new here having taken on the restoration of a 52 3100 Panel for a friend , we want to do the mythical 3.55 rear end upgrade whilst keeping the truck as standard as possible , could either of you give any details , part numbers etc for the ring and pinion you used and where you got them . your help would be much appreciated , thanks John
I purchased mine through mothertruckertrucks, they used to sell outright but now use eBay. Very good experience, make sure you order the truck ring and pinion and not he car version.
It's listed as follows: 1940 1941 1947 1948 1949 Chevy GMC truck 3.55:1 Ring and Pinion Gears 1/2 ton GM
Yes, the eBay listing is :
"1940 1941 1947 1948 1949 Chevy GMC truck 3.55:1 Ring and Pinion Gears 1/2 ton GM"
If that is the listing, the description is more extensive:
"New 3.55:1 ring & pinion gears for all 1940-1953 Chevy & GMC 1/2 ton trucks."
And, it could be noted that it will work on 1954 1/2 ton trucks, if you use an earlier ring-gear carrier?
New bearings also make a big difference on how well the assy. goes back together. I was fortunate to find all NOS american made
bearings for the pinion, axle and carrier all on Ebay. Dont forget a new Oakie bushing as well.
I will be getting my extra rear end and torque tube soon from the field it is in to take apart to look into the same swap my tube is a Canadian truck so will be looking for either a carrier or maybe drill the carrier to accommodate the ring gear.How did you order your gears from mother trucker I don’t see a website or are they on eBay under mothertrucker.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Ebay, use the username I specify in my first response email
You can contact him through PM here on Stovebolt. Mother.Trucker
Yes, cant say enough good about the quality of the ring and pinion. If you want OEM smooth and quiet these gears are the answer. I too purchased all new pinion and diff bearings nos off ebay. Gear setup was straight forward, also a great time to install an okie bushing while it is all apart.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
You might want to also consider the:
- installation kit
- drive shaft seal (Okie bushing)
- u-joint repair kit
Buy the kits or buy the new parts.
Jim Carter & Chevs of the 40s should also have parts/kits?
Thanks will be considering all of the parts recommended by Tim .I have a extra tube and diff assembly I want to take apart to see how difficult it is going to be .I have been reading lots of posts about the swap the extra diff has bendix brakes on it but I don’t know the year it was from My truck is a 54 but had a different rear axle in it so I used one from a 51 truck .
"The Journey"
Follow in the DITY
Bendix brakes were standard on all wheels on 1954 3100 trucks.
Moderated
Moderated
Thanks everyone for the information , much appreciated . I may have located one here in UK.
In my research I also found this .... .
http://www.oldchevytrucks.com/cart/product.asp?prodid=HP163&i=10012|||||
Does anyone have a link to a master install kit for this ?
"Does anyone have a link to a master install kit for this ?"
One link is in my post, above.
Did you check Jim Carter?
Chevs of the 40s
Get a kit that matches your year.
