1 members (wilbur53),
92
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 2 Moderated | | Moderated Joined: Nov 2019 Posts: 2 | All,
I rebuilt my 1949 Chevy Truck Carburetor (Carter W-1) that did not run in ~ 5 years. I removed lots of rust and gunk; I clean it using carb cleaner. After I put it back together and installed it ran good for a bit and it started to spilling gasoline thru the metering rod housing. I took it apart again put it back together and it is doing the same thing. I’m no mechanic but I know how to follow instructions. Any ideas what can be causing this? | | | | | Joined: Nov 2002 Posts: 2,775 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,775 | (A) defective fuel valve (B) fuel valve out of adjustment (C) defective float (D) too much fuel pressure (electric pump???) (E) too much fuel pressure (fuel tank vent not operational) (F) - rare - cracked bowl cover in area of fuel valve
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | (G) Defective fuel filter or lack of, letting dirt in to fuel valve ( needle & seat ) | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | One of mine, I run two on one engine, had the float go bad. I was out running around town all morning, can home and parked in the driveway. Went out an hour later, fuel everywhere. The seam in the float gave out while setting, truck was running great all morning. | | |
