4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
Moderated
Moderated
All,
I rebuilt my 1949 Chevy Truck Carburetor (Carter W-1) that did not run in ~ 5 years. I removed lots of rust and gunk; I clean it using carb cleaner. After I put it back together and installed it ran good for a bit and it started to spilling gasoline thru the metering rod housing. I took it apart again put it back together and it is doing the same thing. I’m no mechanic but I know how to follow instructions. Any ideas what can be causing this?
Carburetion specialist
(A) defective fuel valve
(B) fuel valve out of adjustment
(C) defective float
(D) too much fuel pressure (electric pump???)
(E) too much fuel pressure (fuel tank vent not operational)
(F) - rare - cracked bowl cover in area of fuel valve
Jon.
The Carburetor Shop
(G) Defective fuel filter or lack of, letting dirt in to fuel valve ( needle & seat )
One of mine, I run two on one engine, had the float go bad. I was out running around town all morning, can home and parked in the driveway. Went out an hour later, fuel everywhere. The seam in the float gave out while setting, truck was running great all morning.
