6 members (Shaffer's1950, Otto Skorzeny, Ponchogl, Cletus1950, Barry Martak, Peggy M), 111 guests, and 1 robot.
Topics128,134
Posts1,056,403
Members48,441
Has anyone here ever tried low temperature epoxy primer? How was it?
I've got my body off the frame and am hoping to brush on some undercoating this winter.
There are a couple low temperature epoxies that pop up on google:
https://www.epoxy.com/899cold.aspx
https://protective.sherwin-williams.com/detail.jsp?A=sku-26767%3Aproduct-7006
The garage isn't heated, or substantially insulated and I'm not sure how effective heaters will be... maybe if i get several propane tank heaters?
Expecting daily lows in the teens/20s and highs in the 30s/40s for the next few months.
'59 Chevy Suburban, NAPCO
Those two products you posted look like they were for concrete and masonry substrates, not necessarily metal.
Even if you do find a product that will work, you'll have to keep the temp up to at least 50F. You need to VENTILATE (see this post), and ventilation takes lots of heat to offset the cold air coming in.
Sir Searchalot
Sir Searchalot
Wait for warmer temps to be within paint recommendations. If you can't wait, build a "tent" around subject, heat inside tent, wear breathing gear.
We don't know if you are painting a bus or a cooper mini or just parts. Makes a big difference.
Even if you are able to paint in a "warm" tent, the paint will be curing for a few days at freezing temps overnight. NOT GOOD.
Thanks for the input guys... and good catch about those other epoxies being for masonry.
epoxy.com did not respond to my questions about using their low temp primer as a truck undercoating.
I can only speculate that it probably isn't as flexible as something meant for metal.
So I decided to get a bunch of heaters and some tried/true SPI epoxy primer.
Southern Polyurethanes is some gooood stuff!!
Sir Searchalot
Sir Searchalot
SPI, as said, has the best Epoxy primer and advice. Google "The perfect paint job" by SPI.
SPI to the 3rd power here.
Keep in mind that your paints and sheet metal need to be up to 65+ degrees also. You don't just heat up the space and go to work. It may take hours for them to reach temperature, so point being, use a laser thermometer to be sure paint and sheet metal is up to temps before you start painting.
