2 members (Gdads51, 1 invisible), 150 guests, and 3 robots.
Topics128,131
Posts1,056,367
Members48,441
Hello,
after rebuilding the engine, 235 cui, build 1953, of my truck I have one question. Where musst I connect the hoses for the seperat oil filter?
Have a look here: https://www.kripahle-online.de/unterricht/wp-content/uploads/2019/12/Bild-013.jpg
Which hose where fixed on the left side, which one where fixed on the right side?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Stovebolt.com has a couple of Tech tips covering the subject. Read those and see if what you need is there.🛠
Ex Hall Monitor
Ex Hall Monitor
The feed hose connects to the aft port, the same port the oil pressure gauge connects to. The return hose connects to the forward port.
You need one of these Tee's for the aft port so you can connect the filter and the pressure gauge.
Harold
Harold
Hello, thank you for your answers.
Wolfgang
This is how my external oil filter is connected on my rebuilt '58 235 engine.
Moderator, Electrical Bay
And for something completely different, I ran a full-flow filter on the other side of the block sending the connecting tubing out the old mechanical fuel pump location...like this:
~ Jon
