3 members (Hotrod Lincoln, Peggy M, Pre '68 Dave), 71 guests, and 7 robots.
Topics128,012
Posts1,055,318
Members48,419
#1336016 12/01/2019 11:57 PM
Hello;
Trying to get back at this project....Working on the propeller shafts and found the U joints in need of replacement. I found a Spicer catalogue on line and it looks like #5-178x will work.
Can anyone confirm this or have a current model # that works?
This is for my 52- 9430 1 ton
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
52_Ton #1336031 12/02/2019 1:31 AM
I used that part number on my '48. I had to modify one of them for some reason that I can't now remember, grinding a little metal off for wrench access or something similar. Not a big deal or I wouldn't have done it.
52_Ton #1336032 12/02/2019 1:52 AM
Crusing in the Passing Lane
Measure old ones, search by dimension.
Ed
52_Ton #1336250 12/03/2019 5:46 PM
1 Offline
Should be a Spicer # 1350. If you ask for that at O'#### or similar, they will want an application and their books don't go back that far. So pick a u-joint for a Chev 3/4 ton from however far back their books/computer go. That should be a #1350. Next size up is #1420. That won't fit. Take the dimensions with you to check.
1951 3800 1-ton
In the DITY Gallery
1Ton_tommy #1336255 12/03/2019 6:23 PM
A better solution would be to go to a driveline specialty shop and ask for a #1350 u-joint. There's one near where I live. They don't ask you year, make, model, engine, paint color, etc. They just get you what you need. They carry quality (Spicer) parts at better prices than your generic parts store.
klhansen #1336310 12/03/2019 11:43 PM
I used the Spicer catalogue to cross reference the 1350. I also used an indicator to measure to confirm the size.
52_Ton #1336311 12/03/2019 11:45 PM
There's actually a place here in Pgh Pa called Driveline Service that I've delt with numerous times. I've got joints installed while I waited cheaper than I could of bought em and Installed them myself. Not to mention ,"the support small businesses thing " I like to do. I'm sure there should be something similar in your area. Hopefully
52_Ton #1336312 12/03/2019 11:46 PM
Humm. Nice chart
52_Ton #1336314 12/03/2019 11:51 PM
I ordered 3 today and will confirm they work/ fit proper
I like doing the work when I can. The old u joints needed to be pressed out.
52_Ton #1336315 12/03/2019 11:53 PM
You can use a ballpoint clamp/press without attachments. It works quit well really.
glenns towing #1336316 12/03/2019 11:56 PM
I couldn’t get enough force to budge them, even with heat. The press worked great.
This is the Spicer Catalogue link
https://media.spicerparts.com
52_Ton #1336338 12/04/2019 1:26 AM
I second using the balljoint (probably a spell-check glitch Glenn) clamp/press for u-joints. It's way better than the neanderthal hammer and socket method. I bought one of those a number of years ago and even use it for ball joints. wink
That Spicer catalog link is a good resource, too. I've saved a few of the items from there on my computer for reference.
52_Ton #1336342 12/04/2019 1:43 AM
Lol. It was. computerdeath
Moderated by  Dusty53
