1 members (baldeagle), 46 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#1333385 11/11/2019 10:24 PM
Was given an under hood lamp bracket - probably a repop - and want to install it in my 49. I do not intend to have it work but thought it would be different.
Looking at the bracket I assume it would mount parallel to the front/rear hood seam. But there are no mounting points. If I mounted it at a right angle to the seam the two bolts (on either side) of the seam at the rear bracket might work. This would have the bracket perpendicular to the hood seam. Would this be correct? If yes, which side does it go on? Driver or passenger?
If it is I am concerned about removing the existing bolts to install the light bracket fearing I would upset the hood alignment/seam. I would remove one bolt, install the bracket loosely and then remove/replace the second hoping this will not affect anything.
Thanks.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I guess I didn't give this enough thought before posting. The two elongated holes in the bracket are what I use and not the two smaller ones. It then mounts on the two bolts on the rear bracket, possibly on the passenger side.
Now going back to my question, will I cause any problems by removing/replacing the two bolts one at a time?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
N.O.S. underhood lamp on my '48 Chevy 1/2 ton truck. I had no issues mounting the lamp a few years ago.
That is like mine. Have you wired yours? Is the mercury switch in the actual socket? Finally where did you wire it to. Voltage regulator?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Bill--
My lamp is wired directly to the voltage regulator--on the battery side. The mercury switch is located in the socket.
If my memory serves me right, there is a manufacturer name stamped on the arm of the lamp.
LUKE
Thank you Luke. A picture is worth a thousand words they say.
bill
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Is this hood lamp a "John W Hobbs" make or did GM make one?
Thank you for any information.
Todd
1950 Chevy 3100
That's great information!
I'm trying to locate one. I have seen one advertised as a chevy sedan. But it's the same exact light.
Todd
1950 Chevy 3100
I'd love to have one of these in my truck
Craig
I mounted one i saved from a 90’s gm truck. Its the retractable type. Works great. I’ll probably never use it but at least i have it.
I just bought one from Flea-Bay. $80 shipped. Looks pretty original including wire. I'll post when it arrives. RE John W Hobbs lamp.
Early Christmas gift to Myself!
Todd
1950 Chevy 3100
I get my underhood lamps from a cadillac at a U-pull yard. They look just like the originals and are cheap. A couple bucks.
Fiddlerpin--can you share a photo or two with us of what you have harvested? What model/year of Cadillac?
