Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Hello, I recently swapped my (1947) 216 for a (1954) 235 in my 47 Chevy fleetline. One of the last things I need before I get her on the road is that I need pictures of the gas pedal linkage to the carburetor. The swivel point on the 235 is about 3 inches shorter than on the 216. If someone can help me out with some nice pictures where I can see the swivel point on the engine, the linkage setup, I would really appreciate it. I haven't been able to find any good ones on the internet. Thanks for any help beforehand.
Classics, I recently swapped my 216 for a newer 235. I was able to utilize the same linkage from the carb to the swivel point on the block. I did have to shorten the rod from the pedal to the swivel point. Just measure, measure a second time and cut the rod. Don’t forget to leave a 3/8 extra. You’ll need to heat and bend that 3/8 to a 90 degree bend for the swivel connection. Then drill a hole for the cotter pin. Jim
~ Jim Schmidt, Bucks County, PA 1953 Chevrolet 3804 1-ton In the DITY Gallery
Hi Jim, thanks, I just cut the rod midway and will weld it once I figure out the setup of the linkage. I want to mock it up first and make sure everything is smooth, ill wait for a nice picture from one of the members just to make sure everything is correct. Its cold and raining in Northern California so im not in too much of a hurry. Thanks again.
Where is this Eureka, you talk about? LOL I use to live in Cutten, way many years ago while in college. I think my throttle linkage was cut and welded when we switched from a`216 to a 235.
Craig
My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
Thanks Jim. If not tomorrow, whenever you have the chance, the weather is pretty bad anyways. But the sooner I get this wrapped up, the sooner I can drive her (spring time im sure)
Here are a few different pics. Blue motor is a spare i have sitting. Grey is my 261 in my 51 2dr sdn. Not sure if they will be any help. I thought i had more pics, but cant seem to find em. I actually did a bit of trial and error to get my linkage to work in my car. Just took patience. Which i very little of ... lol
As is usually the case, nobody can view your Photobucket pictures. Links and random surveys block access. Instructions for posting photos directly to Stovebolt are in the left margin of every page and are very easy to use. Even a complete computer dummy like me can do it.ðŸ›
Thanks for everybody's help, With your pictures I was able to figure it out. Now im very close to getting her back on the road I simply needed to bend the linkage going to the carburetor a bit to adjust for the shorter throw. The coupler is temporary until I find the perfect position. Ill mark it, and weld it.
Glad to see you are getting there. Some time, if you don't know yet, get the year of your 235 for future motor mods. I run a '63 235 in my green turd.
Craig
My question is, what is the skinny on what year was the pivot changed for the 235 engine in trucks? Some of us have put car engines in our trucks. Are there differences in pivot points between truck and car engines?
Your green turd, hahaha, that's a loving nickname. I actually recently bought this engine from a fellow stovebolter after the original 216 spun a rod bearing. Its a 1954 235 he completely rebuilt and delivered to me. Same front motor mounts made installing it easier. Used my old bell housing. The exhaust manifold is the angled type instead of the horizontal type so ill have to get the pipe re-bent. Other than that, she's pretty much ready to roll. Already ran her for a few seconds (after manually running the oil pump. Does anybody know how to time these engines? Is it just by feel, or can you put the timing gun to the flywheel? I also have the head off of a 1960 235 that should give me about 15 more horsepower due to the higher compression. It would need to be rebuilt, might swap it out in the future for a few more ponies.
That pickup is beautiful, I have seen it in person as is the 47. You are one lucky fellow. Take a picture of the timing marks on the flywheel and post. You will want to shoot for 5 degrees before tdc. Hook the timing light to a spare 12 volt battery and connect to the number 1 and shoot for the 5bdc mark on the flywheel. click on the link below Steve
1953 Chevrolet 3100 261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY Gallery Video of the 261 running
1964 GMC 1000 305 Big Block V6, sm420, the next cab off restoration
Holyshizzle! She’s a beauty Clark!! I love the Art Deco and I seen that paint theme somewhere else if I recall correctly. Nice choice. Do you have a photo file of her somewhere? Love to see more of her! Jim
I have a few more on my Instagram, but I don't know how to link to it unfortunately. Heres a few more of her now with a fulton sun visor I got her. Thanks for the compliment.
Hey Jim, that's grass I take to a friend as feed for his cows, One of them used to be my Jersey and I still milk her. The milk tastes much better when you give them fresh cut grass.
Wow, that's a beautiful '47 Aerosedan you got there! A good inspiration for me--I've got a '46 Aerosedan in my garage, a long-term project. I've got a '53 Powerglide 235 in the shop right now getting rebuilt for it, so I'll be going through the same process in getting it set up. I'll also be rebuilding the 3 speed and the front suspension. Thanks for the pics--nice to see more Stovebolt-powered cars on here, in addition to the trucks!
Oh, a 46, sweet. I love the side molding that goes from the back all the way up the hood. I wish the 47-48s had that too. Put up some pictures when done. I hope you don't have much trouble getting it in the bay. Let me know if you have any trouble. I probably went through it, though it wasn't too much of a hassle in the end. Your not at this point yet, but if your front motor mount holes (timing chain cover) don't line up with the frame motor mounts, I made a jig that you can bolt on and helps to make the new motor mount holes. I hope I explained it well. But you'll see later.
Thanks Glen. I was driving it quite a bit until the 216 gave out, it ran nice and smooth, but those babbited bearings coupled with the very low oil pressure made one of them wear out. It took me a while to find a nice 235 to replace it. But now im about 1-2 weeks from getting it back on the road, and trust me, im going to drive it, perhaps a nice long drive when spring comes. Ill definitely post pictures. I bought it out of north Dakota, but it must have been driven seldom because it had very little rust, and most everything on it was original to the car. Im proud to own it and cant imagine ever getting rid of her.
Well it seems we are transitioning from a truck site to a car site.☹️ Ok Tiny, time for some pics of your beauties.
Well actually I've drove it for 3years with the 216. Alitta smoke and alotta leaks, but didn't run bad. The clutch decided to crap out and 2nd gear was noisy. I put a 261 with a 235 head on it that I had waiting. I also put another 3 speed in it out of a 49. Wanted to keep the column shifter. Pertronix ignition, 12 volt with a generator, relocated oil filter, splits and duals. Also put 3.55s out a powerglide car. Standard trans had 4.11 i believe. Only two options to keep the torque tube. I been driving it this way for another 3 years or so. Yea, door dings and rock chips go unnoticed to say the least. Lol
Here's a pic of my 51 2dr Sdn. I feel the same way about it as you do with yours. Always nice to see a stovebolt powered vehicle, weather it being a car or a truck.
Very nice Stovebolt
