| | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I was wondering if anyone knows of a power steering box out of a late model chevy that would fit in the original location in my 1958 NAPCO 4x4? Or can the gear ratio be changed to make it easier to turn? Or is there a kit? If it helps the box is in the same place as the 2-wheel drive trucks.
Michael | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Come on guys/gals, does anyone have an idea? Lets be creative, this is the hi-po shop right? | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | This is a tough one, My 57 NAPCO and the one other one I have driven steer really hard at low speeds (especially from a stop). I would try the NAPCO Users group. They have a link on the Links page. I would be intersted in what you find out, good luck. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | That was a tough question. It's so specific, that someone wouldn't know without direct experience. Not trying to ignore you, but I simply don't know.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | Jomichael, My '59 is not a napco,but was converted to 4wd by PO. It has a steering box, and drivetrain out of a '74 K10. The box is mounted outside the frame rail with some funky hardware but it works. My front axle is a Dana 44 so I'm sure it is diff. than yours, but the power steering is much appreciated when tring to turn the 33"s! I'm hoping to clean up the steering shaft and U joints in the linkage soon, perhaps with stuff from Flaming River, maybe they have something for you. Good Luck!! Jeff
220 - 221 whatever it takes
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | the ez but expensive way is to find a 55-59 gmc 1/2 ton to 1ton truck with power steering and use that. it has a speacial saginaw box that will bolt to the three holes where the original steering gear bolted. On a chevy, the top of the frame may have to be cut out for clearence. These boxes are very hard to find, and you can expect to pay a lot of money if you are lucky enough to find one. the steering column needs to be changed as well. the column is coupled to the steering gear with a modern stile flex coupler. | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Is The steering box in the same location as a 2 wheel drive? If it is I used a steering box off of a 77 chevy pickup 2 wheel drive. and mounted it on the out side of the frame and from there you could probably rig up something that would work for you. Have you checked to see if the power steering kits from like Chevy Duty for 99.00 bucks would fit?
38 original 48 panel 59 stepside 46 in the back forty
