5 members (greenie-reddy, frogfarmer, Gray_Ghost, 2 invisible), 315 guests, and 5 robots.
Topics128,156
Posts1,057,018
Members48,460
41 AK Bucket O’ Bolts
Got a retirement project,
1941 Chevy 1/2 Ton Pickup (AK)
Want to rebuild existing 216 ci. engine. BUT its a mess, so I'm exploring purchasing one in better condition,
I hear they are all over the place, but I must be looking in the wrong places.
Any suggestions? Thanks...............
1941 Chevrolet 1/2 ton Pickup. AK.
welcome to Stovebolt....... put an ad in the parts wanted forums.
Welcome to the Stovebolt madness. There is no cure! shake
Welcome aboard! Half the fun is searching for these old parts. Good luck.
Welcome to the 'bolt. the 41-46 is my second favorite model group...
Another quality post.
Real Trucks Rattle
What parts do you need? I have several 216's in the scrap pile but no precautions were taken to protect them from the weather. One with a new carb, generator, starter, fuel pump, water pump, and gaskets appears fresh but it is split down the whole left side from freezing. It's been in the pile since last summer without a valve cover so who knows? If your block can be bored and babbited it might be of some use.
Evan
Welcome to Stovebolt.com
We are about 100 miles from each other.
If you want to contact a specific member about parts, do it in a Private Message.
Any Person-to-Person conversations/negotiations should take place in Private Messages.
If you want obtain a part (like obtaining an engine), do it in in a Parts Wanted ad.
If you want to ask about vendors of specific parts, post those questions in the General Forum.
I think you have to make about 5 posts before you can PM or place a Want Ad?
So, posts about your truck and where/how you found it, and what you want to use it for, and what you need to do with/to it.
Check out the Tech Tips for all sorts of advice/information (a lot of questions can be answered there):
"Getting Started" in the Tech Tips is a good place to start.
Crusty Old Sarge
Crusty Old Sarge
Welcome to the site. Glad to have another Southern Bolt join the fun.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Semo, where is como n.c. located? i'm close to n.c. line. if your close to Spartanburg, or Gaffney the hot dogs and Pepsi are on me!!
ha...thanks tim.....i could look it up but my pc is down and i hate this laptop. what a waste.
......thats quite a ways from me, semo, but thats a standing hot dog invite!!!
Thanks i will do that👍😊
Little bit of a ride, near Franklin Va
Thanks 👍
Thanks, looking forward to being a part
Would love a working engine, and tranny is shot too. Thanks for the response. Any suggestions are appreciated
Semo, please understand only about 1% of the site membership even look at this Welcome Center Forum. You will get more views and answers if you post in the garage forums. Read the post by Cletis on Why posts are edited, deleted or moved, at the top of the General Truck Talk Forum for guidelines on using the site.
AD Addict & Tinkerer
Welcome to the “Bolt”! A wealth of knowledge is at your fingertips and all you have to do is ask!
You may consider a later 235. I not sure but I think a ‘53-‘54 may just bolt in and is a full oil pressure engine. Maybe, another more knowledgable expert could chime in. A later 235 would also work with a few modifications. These are definitely more abundant and easier to find. They were made up to ‘62.
Phil
Project Journals
Stovebolt Gallery Forum
1954 was the first year for high-pressure 235 engines. There might be a few 1953 car 235 engines that were high-pressure oil systems.
As Phil posted, post 1954 and post early 1955 235/261 engines need to have their water pump location modified (for appropriate cooling).
Big Bolt Forum Moderator
welcome to the site!
Mike
Welcome to the forum Semo!
There are a few later model 235's for sale around me from the $100-$450 range if you are thinking about swapping in a newer motor.
'55 Chevrolet Grainer
'57 Chevrolet 210
Always good to see a fellow North Carolinian on here. I'm a fur piece from you in Allegheny County, extreme Northwest corner of the state in the Blue Ridge Mountains.
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
