2 members (Otto Skorzeny, carbking), 125 guests, and 1 robot.
Topics128,050
Posts1,055,760
I signed up on this site about eight years ago and then the rest of my life happened.
I finally gave up on the idea that I and my son was going to be able to work together and restore "Floyd" my 1946 3/4 ton Chevy pickup. I had it towed out of the barn to a well respected mechanic to rebuild the engine and put in a new wiring harness.
I have few mechanical skills, but I love old trucks and intend to drive Floyd with great joy and pride for the rest of my life.
I need a wiring harness,maybe a new engine or rebuilt and lot of other parts. I also have lots of extra part that I can trade, sell or pass on to other Stovebolters.
Any help or suggestions will be greatly appreciated.
My name is Ronnie Ray Carper and I live in Eugene Oregon. Any Stovebolters nearby?
Thanks in advance for any suggestions.
R2
Hello Ronnie, check out the "side lot", there is a forum for the west coast. There are many small jobs you can do yourself with just a small tool box. Check you tube for videos, they have one for just about everything. Otherwise, ask about the task in the appropriate forum on the 'bolt.
Another quality post.
Real Trucks Rattle
Very expensive, and excellent quality, cloth-covered original-appearance wiring harnesses are available from several vendors.
Lower-priced excellent quality plastic-coated harnesses are also available.
Ask for names/opinions of vendors, if you need them.
Check out the Tech Tips section here on Stovebolt.com. There might be some articles of interest to you. There is a Tech Tip on documentation that you might find to be useful.
When you post each query/post about your truck, in each new post be sure to post the minimal info about your truck (make, year, model - and, if you want to stay close to original or if you would consider upgrade/modification).
Do with your truck what you would like. If you want opinions on what to do/change, just ask.
Welcome to the Stovebolt madness. There is no cure! shake
