| | | Forums66 Topics128,008 Posts1,055,285 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 89 Shop Shark | | Shop Shark Joined: May 2006 Posts: 89 | Do I have room on a 1947 3600 for 235/70/17 tires? Stock ride height, stock suspension.... | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | You should have room since that tire is only 30" tall. The only thing that you might run into trouble with would be your offset
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | I would say yes. Im running 225/75/16s on ford wheels on my 3/4 ton and i have plenty of room. Only place i had clearance issues was from the actual wheel offset. Was just rubbing the outer tie rod when turned. Some trimming and a spacer fixed that. Many others have run into the same problem on the site. All is well now👠| | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | My spare is a Dodge 3/4 ton 8 bolt rim and it clears the tie rods no problem. Mind you my truck is a 60's model and might have more clearance to start with .
good planning is no substitute for dumb luck
