2 members (dt235sd, 1 invisible),
114
Mod | | | Forums66 Topics128,153 Posts1,056,827 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | Trying to go with a factory look on the new 235 going in my 37 so was everything except the starter,generator and distributor painted all the same color. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Yes...The engine was built with the water pump and fan, manifolds, draft tube and bell housing installed and then painted Gray. Mike B  | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Jeff, you may have already seen this, https://archive.org/details/MasterHa1936 , from 1936, it is a very detailed film about building cars. I really like the engine section in the beginning. There are three or four parts to it. | | |
